Drum to Disc
  • ck1105
    • Feb 2006
    • 85
    Drum to Disc
    Has anyone done any research on swapping drums for disc brakes? I have a tandem axle dorsey and need new brakes anyway, i have been considering the switch, what all is involved and can it even be done, also can you switch it from two tires to all four? Any info helps, thanks....
  • ag4ever
    • Feb 2004
    • 1180
    RE: Drum to Disc
    Yes it can be done. Sometimes you can even keep the same actuator, with one modification. You have to poke a hole in the risidualy pressure valve.
    The brake themselves are just a matter of unbolting the drums, and bolting on the disks. Even adding a second set should not be a problem.
    I would say the only thing to check is that your actuator can produce the required pressure for disks, as they do require a higher line pressure.
    • ffmedic74
      • 835
      • Lexington, KY
      RE: Drum to Disc
      I did this and ended up buying a disk brake actuator (has more power to compensate for less pad), reverse lockout, and kodiak disk brakes. Worked very well!
      • Rick
        • Mar 2004
        • 1250
        • San Diego, Ca
        RE: Drum to Disc
        There is a how-to article in either the july or August TrailerBoat magazine. I would suggest you use UFP pieces They are used by alot of tralier companys Here is the link http://www.ufpnet.com
        Nautiqueless in San Diego
        • MNSuperAir
          • Sep 2005
          • 591
          • St Paul
          • 2016 SAN 210
          RE: Drum to Disc
          I have also been looking into this. Follow the attached link and download the .pdf for doesey replacement parts. Then give them a call. They are very helpful. I haven't made the switch yet, but hope to.
          www.trailersbydorsey.com
          2016 SAN 210
          2006 SANTE sold
          2001 SAN - sold
          1991 Sport Nautique - sold
          • MNSuperAir
            • Sep 2005
            • 591
            • St Paul
            • 2016 SAN 210
            RE: Drum to Disc
            Sorry to beat this to death, but I just got off the phone with Jeff from Dorseya nd he has a kit to change over to disc. Price for me was $380 which included a new master cylinder and converting the drum to disc breaks with oil bath.
            2016 SAN 210
            2006 SANTE sold
            2001 SAN - sold
            • Rick
              • Mar 2004
              • 1250
              • San Diego, Ca
              RE: Drum to Disc
              Sounds like a steal to me. Male sure you have a 5 wire electrical on your tow vehicle. the 5th wire is blue and is a reverse actuated signal to allow you to back up.
              • ag4ever
                • Feb 2004
                • 1180
                RE: Drum to Disc
                Most actuators for disk have some form of "jamming system" to prevent the brakes from getting pressure while backing. It can be as simple as a pin that is added before backing. This keeps you from having to have the 5-wire setup, but the 5-wire is much better.
                • MNSuperAir
                  • Sep 2005
                  • 591
                  • St Paul
                  • 2016 SAN 210
                  RE: Drum to Disc
                  The "kit" that Dorsey was talking about included an actuator that was activated from the 5th wire. Seems like a good deal to me. I may just have to buy it. It was going to be a winter project though.
                  2016 SAN 210
                  2006 SANTE sold
                  2001 SAN - sold
