Normal oil pressure for a ZR6 running the shell rotella 15w40?
My manual for a 2007 says 25-80 psi at 2,000 RPM. 10 psi minimum at idle.
You really should run PCM's recommended oil, which is not 15W-40 for that engine.
https://www.planetnautique.com/vb5/f...specificationsI own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
