Engine running rough/popping at high rpm
  • ckevans98
    • Aug 2019
    • 25
    • pittsburgh
    • 2006 super air natique 220
    I have a 2006 super air antique 22’ with zr 6 engine
    starting this season when I would be going full throttle I would hear a popping from the engine. Sounded like it is coming from the exhaust.
    I changed the fuel filter and put in some sea foam.
    that apparently is not the cause
    the boat will run ok under 3000 rpm with intermittent hesitation
    if I load the ballast tanks and try to surf or wake board it consistently stalls out like it is missing or has bad fuel
    the popping from the engine/ exhaust continues as well
    any help with a diagnosis would be greatly appreciated
  • Tactical23
    • Aug 2018
    • 9
    • Germany
    • g23 2018
    Check the air filter, clean/exchange sparkles, check system diagnostics (if its already available 2006 boats)
    • ScooterMcgavin
      • 1478
      • 2014 SAN 210 TE
      When was the last time a tune up was done? If it’s been awhile I’d start with plugs, wires, rotor, distributor cap.
      1989 Sport Nautique
