Prop help/opinions
  • jseski
    • Jul 2020
    • 2
    • MN
    • 93 ski nautique (purple)
    Prop help/opinions
    I'm sure this has been discussed elsewhere on here, but I can't find it. At least not for my unicorn (aka 93 ski nautique, the primary unique part being RH rotation & 1:1 tranny...and then it's purple). All I've found is discussion for the other more common transmission ratio.
    So for my 1 to 1...
    I'm quite sure it originally came w/the oj 13x13 3 blade.
    Anybody know the various replacement options that would fit, 3 blade vs 4 blade, size, pitch, etc; and then the subsequent benefits of those options??
    Example: the xyz ### prop is a 13X13 4 blade good for all around, but if you were primarily looking for top end go with the xyz #### prop with a 13x__ , and if you wanted better speed hold for wakeboarding/surfing pushing extra weight (fat sacs) around the lake, the abc ### prop __ x __ will hold speed better ... stuff like that would be GREATLY appreciated!
    thanks in advance...
  • XBIGPUN66
    • Oct 2012
    • 456
    • WI
    If you call acme and tell them your configuration they will suggest props for you
    Ian S
    • jseski
      • Jul 2020
      • 2
      • MN
      Thanks, yes, I will try acme & get their advice, too (I've already talked to "wakemakers.com" staff). But I thought I'd see if there was anybody that had some practical, on water experience with that age of nautique, or another make with the 1:1 ratio & the best pitch for slalom, footing, or holding slower-speed activities (trick, wakeboard).
