Transom light fault code for underwater lights
  • fairbray
    • Jul 2020
    • 1
    • Austin Texas
    • 2017 Super Air Nautique G23
    Just took delivery of a 2017 G23 with just over 40 hours. Everything was working great and then I got a fault code for the underwater transom lights. They wont work now. Does anyone know if its an easy fuse fix or do they need replaced?
    The dealer will take care of them but I do not have a lift for a couple weeks (they are backordered) and my boat is in the water at the marina. I want to try to avoid bringing the boat to the dealer if at all possible due to convenience.
  • Infinity
    • Sep 2017
    • 730
    • Lake Norman - Denver, NC
    • 2014 SV244 w/ ZR409
    There may be an in-line fuse somewhere, trace the wires.... you should also check the connections where the underwater lights plug into the harness. Typically the wire connector is plugged into the harness at the transom of the boat, likely zip tied to the top cap. It may have also popped a smaller breaker or a relay
