Are the heaters on a GS22 both the same length or is one shorter than the other? If different - is there a way to make the short one longer?
To make the tube longer just follow it back to it’s origin at the heater or plastic “Y” adapter. Remove the hose clamp to remove the tube. Install a new tube of your desired length and fasten it with the hose clamp. The length of the tube will be limited to the size of the compartment needed to contain it when not in use. If I am not mistaken you can by 3” tube up to 50’ in length... more than you would ever need I suspect.
