Keypad Replacement - 2001 Air Nautique
  • jchristian
    • Jun 2019
    • 5
    • Connecticut
    • 2001 Air Nautique
    I need to replace the keypad on my 2001 Air Nautique. I'm wondering what is needed to program the master code into the new keypad. (I see several threads on how to program the primary user code, but not the master code.) Has anyone done this replacement and have specific instructions? I'd like to do it myself and save money. Thanks.
  • Fast351
    • Oct 2006
    • 315
    • Winsted, MN
    • 2001 Ski Nautique
    I seem to remember the master code is part of the dash "brain box" so there shouldn't be anything to program. But my memory is getting worse every week
    2001 Ski Nautique / 2007 SV211 TE (gone but not forgotten)
    • jchristian
      • Jun 2019
      • 5
      • Connecticut
      • 2001 Air Nautique
      Update - Easy Fix! Thanks Fast351! There is no programming. It's plug and play! For anyone else needing to do this, it takes about 10 min. You'll need a 3/4" socket for the steering wheel nut (just mark location with a sharpie so you put it back in right place). Five screws holding the pod on (3 come out with a flathead screwdriver, 2 have knobs and come out with finger turns). Just move the pod slightly and you have eay access to the wiring harness, and 2 nuts (3/8" socket) that hold the keypad. Unplug, unscrew, plug new one in, tighten nuts, put pod back, put steering wheel on, done!
