2002 SANTE 5.7l Excalibur Backfiring, lacking power under load
  • Freeheel720
    • Jul 2020
    • 12
    • Truckee, CA
    I just got a 2002 SANTE and it's not quite running right. It has 813 hours on the Excalibur 330 5.7l. When I got the boat, it was stalling when going back to neutral, so I replaced the IAC, but that didn't help. So then I adjusted the butterfly valve to make it run. Now, when I take off under load (when surfing), it backfires and has no power. Also, it can't seem to get out of its own way when it is loaded with some ballast. We have the hard tanks in the rear, and today we put bags on top of them, for a total of about 1200 lbs in the boat. It didn't have enough power to go fast enough to surf, at times. When the boat is empty, it cruises well and tops out at around 40mph. I do not have the maintenance records, but what has been done is:
    IAC from 95 Chevy K2500
    New cap and rotor
    New Fuel Filter
    Checked Fuel pressure, and I have 57psi at the rail
    New Iridium plugs
    New LPP
    Checked compression, all are good and equal.
    Fuel is good
    What could cause the backfiring? I have been searching around on this forum, and I see mention of the cam retard service bulletin, but I don't know how to tell if it has been done. Also, is the IAC from automotive any different than marine? Could that be hurting my performance? I'm trying to get into a shop to check my timing, but they are all backed up for weeks here.
    Thanks for any advice!
    -Arthur
  • functionoverfashion
    • Jun 2017
    • 509
    • New Hampshire
    • 2003 SANTE
    It sure sounds like ignition to me. Since you've done cap, rotor, and plugs, did you do plug wires also? At this point, I feel like it would be an easy thing to try next.
    • Jonny Quest
      • Aug 2014
      • 384
      I would start with Ignition timing.
      JQ
      • Freeheel720
        • Jul 2020
        • 12
        • Truckee, CA
        JQ
        How do I do that? I'm very mechanically inclined, but have never done timing. Can you please point me in the right direction?
        • Jonny Quest
          • Aug 2014
          • 384
          Take a look at this thread
          https://www.planetnautique.com/vb5/f...bur-330-mefi-4
          • Freeheel720
            • Jul 2020
            • 12
            • Truckee, CA
            Thanks! I had seen that thread and I read it mean that I need access to Diacom (or Rinda) to set the timing properly, correct? What about the old "turn the distributor while I'm driving" trick? Any thoughts on tuning by feel?
            • Fast351
              • Oct 2006
              • 315
              • Winsted, MN
              • 2001 Ski Nautique
              Check to make sure when you changed your cap you didn't reverse a couple of the wires. That would behave exactly like this...
              2001 Ski Nautique / 2007 SV211 TE (gone but not forgotten)
              • homer12
                • Feb 2016
                • 584
                • Indianapolis, IN
                • 2004 SV211 TE
                What Fast351 said. Double and triple check you plug wire routing in order of cylinders. It’s in the PCM manual for reference.
                • Freeheel720
                  • Jul 2020
                  • 12
                  • Truckee, CA
                  It was the Throttle Position Sensor. Replaced the TPS and all runs great now.
