V Drive location/ filler plug location 2006 san 22 with zr6 motor.
  • ckevans98
    • Aug 2019
    • 25
    • pittsburgh
    • 2006 super air natique 220
    I am a bit confused as to the v- drive location and where to add oil. The book illustrates the v- drive but not in relation to the entire motor. the v- drive is not separate from the transmission correct? it takes straight 30 wt oil. i have attached photos of what i think is the v- drive under the accessory seat fore of the motor. Please confirm. ty
  • Helmsmn
    • Jun 2018
    • 27
    • Idaho
    • 05 SANTE ZR6
    That’s it. You check the level and add oil (or suck it out) through the dipstick hole. It’s the tube on the right with a cap.
    • Infinity
      • Sep 2017
      • 730
      • Lake Norman - Denver, NC
      • 2014 SV244 w/ ZR409
      That is the V-drive as stated above. FYI, behind the v-drive is the transmission.... the 2 are separate and both have oil, so make sure you are putting the right oil in the right place. Depending on the model is what determines the type of oil, many of the transmissions then used the DEX III. Make sure you look in the manual cause they have some different methods for properly checking the oil levels. Some you check while cold... some have to be checked warm and after shifting from forward/reverse. Too little oil can obviously cause issues but too full can also make problems since if you have too much oil, it can get air bubbles in gear and then not lubricate.
      I would also suggest making sure you do not have any leaks, maybe put some paper towels down there to see if any drips, etc.
      Check existing oil condition too since If too much water gets in the bilge, there is a vent that can allow water into the system. If that happens you want to be on top of flushing & replacing asap or it will corrode the inside.
      • jkallen21
        • Jan 2013
        • 400
        • United States
        • 2006 Super Air 220
        Infinity,
        I’m very interested in this. I own a 2006 SANTE with the vdrive too and I have only known the boat to have vdrive oil (sae 30) and the standard engine oil. Where can I check this other oil?
        • Helmsmn
          • Jun 2018
          • 27
          • Idaho
          • 05 SANTE ZR6
          Originally posted by jkallen21 View Post
          Infinity,
          IÂ’m very interested in this. I own a 2006 SANTE with the vdrive too and I have only known the boat to have vdrive oil (sae 30) and the standard engine oil. Where can I check this other oil?
          The dipstick for the v drive is accessed through the rear seat, center. Lift out plastic box and dipstick is on port side of v drive. It contains 30 wt oil. Looks like a metal cap attached to a tube. This is the one you know about and referred to.
          The dipstick for the transmission, which is between the v drive and the engine, is accessed through the engine hatch. Get your flashlight and kneel on the center cushion, raise the hatch and look down the starboard side of the transmission adjacent to the raw water intake. There is a dipstick there. Looks like a thick wire with a loop on the end. Might be hidden by some wiring and flex conduit. Put your finger in the loop and rotate slightly, gently back and forth to loosen the rubber plug to metal tube contact. Then pull it out. It contains the pinkish Dexron transmission fluid. Refer to your service manual for exact type.
          My boat has the ZR6 engine so I hope your v drive and trans is the same set up if you have the standard engine. I believe it is.
          • jkallen21
            • Jan 2013
            • 400
            • United States
            I will look - thanks. There was Another post on here recently that said that 2006 was the year Nautique moved to a sealed transmission that never needs replacing.
            • Infinity
              • Sep 2017
              • 730
              I dont know of any sealed transmissions unless they just mean a trans has no vent in it that will allow water inside if bilge gets too high. The only thing close that I am aware of are the Power Plus transmissions, they have a square headed plug that screws in, instead of the typical dipstick and they do not have vents (so in essence are "sealed").... they use a synthetic fluid in them that is called "maintainance free", so maybe that is what they meant or where thinking of in that post you referred too. It isnt truly maintainance free tho since you are supposed to replace that trans fluid every 5yrs or 500hrs.
              • jkallen21
                • Jan 2013
                • 400
                • United States
                I found the thread - https://www.planetnautique.com/vb5/f...tion-on-06-210. The comment from H2O says the oil is good for life. You and he agree on the square-headed plug that goes in on these "maint free" transmissions. So now I need to know if I have one of these and then next to figure out if it's good for life or every 500 hours. Do you have a link anywhere showing it should be changed? Thanks!
