HELP PCM 343 won't run - SPN 636 FMI 2
  • PCMGT40
    • Jun 2011
    • 70
    • Denver, CO
    • 1995 196, 2007 210 TE
    We went to ski this morning and I get a fault on Linc.
    SPN 636
    FM 2
    ENG POS Sensor Timing Signal Err
    I put a new Crank Position Sensor on it but it made no difference.
    Any thoughts?
    2011 Nautique 200 with 343
  • Jonny Quest
    • Aug 2014
    • 383
    I believe that you need to have the code cleared. Assuming that the crank position sensor was the culprit, the engine should run after the code reset.
    • PCMGT40
      • Jun 2011
      • 70
      • Denver, CO
      Thanks, it seems to have just been a loose wire in the Crank Position Sensor plug. I just pushed on the the wires and one of them made a little click sound. Put it back together with the original crank sensor and ran prefect the rest of the weekend.
      • boatshoplady
        • Aug 2022
        • 1
        • ID
        Hello! Wondering if you could let me know where the CPS was located on your engine?
