My FCC Passthrough failed this week (I assume due to use of 10% Ethanol Fuel for the past 10 years at least). I installed the retrofit yesterday and all good. However, I was wondering what other parts of the fuel system I should keep an eye on due to possible damage from Ethanol.
Tags: None
Which boat do you have, and what year?I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
Ethanol is a solvent. As a solvent, ethanol can attack rubber parts that have not been specifically designed to withstand the effects of ethanol. Your 2004 engine MAY have been designed to handle ethanol blend fuels. Ethanol (alcohol) is also hygroscopic and hydrophilic. What I would be more concerned with is the potential for "phase separation" where the ethanol separates from the gasoline (due to moisture in the fuel system) and then the ethanol/water cocktail drops to the bottom of the fuel system. It's not too difficult to imagine ways for water to be introduced into the fuel system -- as it's a boat.
JQLast edited by Jonny Quest; 07-19-2020, 11:22 AM.
