2004 SANTE Ballast still filling while running
  • wakeboardjoe
    • Apr 2011
    • 63
    • Texas
    Switch under the dash is on the off position, back in engine compartment levers set to close. This said it still fills while I’m running. Other 2 don’t do this, just the starboard side. Thanks I’m advance.
  • Neptune442
    • Jan 2019
    • 255
    • Henderson, MN
    I hope someone has an answer, because the exact same thing happens (even the starboard tank) on my 2005 SV211 and it's been driving me crazy!
    • homer12
      • Feb 2016
      • 584
      • Indianapolis, IN
      • 2004 SV211 TE
      Switch under the dash might be broken. All my were and I removed them. The valves that close in the back sometimes don’t close all the way in my experience. My starboard tank does the same and drove me nuts. I installed a pvc ball valve behind it and close that if I won’t use the ballast at all. Otherwise, just periodically turn drain on. Mine doesn’t fill very fast
      • homer12
        • Feb 2016
        • 584
        • Indianapolis, IN
        • 2004 SV211 TE
        • swatguy
          • 1631
          • Midwest/ Northern IL
          • 2008 SANTE 210
          All info points to the valve controlled by the dash failing And or maybe popping loose. Those gates were prone to failure
          Here is all you need to know about the issue.
          https://www.planetnautique.com/vb5/f...ballast-valves
          Here is the replacement gate
          https://www.nautiqueparts.com/produc...ntrol-valve-2/
          • Neptune442
            • Jan 2019
            • 255
            • Henderson, MN
            My starboard dash knob is definitely broken. But there's manual levers in the engine compartment to open/close the starboard/port ballast tanks. It looks like the dash knobs tie in behind the manual levers, so it shouldn't matter if the dash knobs are broken...if the manual levers are indeed closed. Like homer says, the manual lever must not be closing all the way.
            • wakeboardjoe
              • Apr 2011
              • 63
              • Texas
              Thank you all !
