vdrive and transmission fluid 1995 GT40
  • chefred112
    • Jul 2016
    • 98
    • Tracy, CA
    • 1995 Super Sport
    Hey All, I've done searching and I've seem to come up with this consensus. tranny fluid type is Dexron III, V-drive is sae 30 oil. sound right to you? I've done this change once 2-3 seasons ago and just want to confirm. I am almost sure that's it as i have a jug of dexron III and a quart of sae 30 oil that I keep in boat at all times.
  • chefred112
    • Jul 2016
    • 98
    • Tracy, CA
    • 1995 Super Sport
    Just changed tranny fluid (easier to do than an oil change). Also, V-drive fluid was crystal clear so I'm just going to top it off...question, would it be an issue if I use 10w-30 as opposed to straight 30 weight...
    • chefred112
      • Jul 2016
      • 98
      • Tracy, CA
      • 1995 Super Sport
      since its only a few ounces anyways i dont think the 10w30 will be a problem..
      • gary s
        • Mar 2015
        • 334
        • Algonquin IL
        I wouldn't. Is it worth damaging something over 5 dollar quart of oil? Shipping alone from California to New Jersey to rebuild alone will cost you big time. Walter at one time recommended 30w non detergent oil,thats what I have been using
        • chefred112
          • Jul 2016
          • 98
          • Tracy, CA
          • 1995 Super Sport
          it wasn't even a quart...literally it was just a swish to top off...i've rebuilt motors and a smidge of oil that wasn't the exact viscosity but ultimately the same oil at operating temp isn't going to hurt...if I was gonna do a whole change out I would just use straight 30...
          • gary s
            • Mar 2015
            • 334
            • Algonquin IL
            Then why in the world did you ask if you had already made up your mind.......
            • chefred112
              • Jul 2016
              • 98
              • Tracy, CA
              • 1995 Super Sport
              Sorry, sometimes I'll ask and answer my own questions but I do value input from others.
