Where do these two connections hook up to??
  • GmtChris88
    • Jul 2020
    • 31
    • Grapevine Tx
    • 210 Super Sport
    I'm guessing battery directly??
  • bturner
    • Jun 2019
    • 1577
    • MI
    • 2016 200 Sport Nautique
    Click image for larger version  Name:	E Sym.jpg Views:	0 Size:	78.6 KB ID:	617769
    Click image for larger version  Name:	Diode.jpg Views:	0 Size:	19.2 KB ID:	617771
    Based on the symbol it is an eyelet. Based on the color of the wire, the direction of current flow through a diode and where the other one is connected to the breaker I would say that they're both connected to a positive bus bar. Typically if they were both going to a battery I would expect them to have a positive or symbol label and possibly a label stating battery.
    You should only have one large cable connection to the battery, not a bunch of smaller cables/wires routed directly to the battery terminal. That is what bus bars are for.
    • GmtChris88
      • Jul 2020
      • 31
      • Grapevine Tx
      • 210 Super Sport
      Thanks! But I didnt see a bus bar in the engine bay.. is it somewhere around or under where the ecu is mounted?
      • bturner
        • Jun 2019
        • 1577
        • MI
        I would actually expect it to be at the power panel. Where is your power panel with the breakers listed on the schematic located?
        • GmtChris88
          • Jul 2020
          • 31
          • Grapevine Tx
          • 210 Super Sport
          Its located on a panel on the fwd side of the engine where the ecu is mounted. Ill take a look around there I guess for empty terminals
          • GmtChris88
            • Jul 2020
            • 31
            • Grapevine Tx
            • 210 Super Sport
            Looking more into this I saw that my boat has the keypad bypassed to a standard key in ignition type system more similar to these schematics. Looks like the red wire is directly hooked to the battery with a fused terminal and the purple wire gets power from the starter relay during start and the ignition relay during run.
