2016 Super Air Won’t start error message DTC 87 primary fuel pressure low pressure
  • Longjj7
    • Jul 2020
    • 1
    • Muskoka Canada
    • 2016 Super Air 230
    Hi,
    anyone know how to resolve
    thanks!
  • hal2814
    • Jun 2016
    • 541
    • Ft Worth, TX
    You’re not getting the right fuel pressure to the fuel rail. That’s usually a fuel pump issue but before you go spending money on a pump check for leaks or kinked fuel lines. Also get a pressure gauge and put it on the rail to verify it’s not just the sensor that failed. Check the wiring to the pumps and make sure you’re getting power. It may just be loose wiring or a failed relay. It could also be a fuel filter but usually a bad filter acts up at the high end, not on startup.
