Besides these basics, which items need to be on your periodic maintenance list?
  • Fast351
    • Oct 2006
    • 315
    • Winsted, MN
    • 2001 Ski Nautique
    So in order of importance, I have the following maintenance items that I do on a regular basis. Aside from these items what else needs to be done on an inboard to keep them troublefree?
    My maintenance list (note these are my time preferences, not based on official schedule):
    Oil change: 50 hrs/1 yr
    Raw water impeller: 100 hrs/2 yrs
    Transmission fluid: 100 hrs/2 yrs
    Fuel filter: 200 hrs/4 years
    Plugs: 200 hrs/4 years
    Cap+rotor: 200 hours/4 years
    What else needs to be done? I'm particularly interested in the shaft seal and rudder/steering cable maintenance, but anything else you guys can think of would be appreciated. I mean does anyone replace engine belts before they start cracking???
    2001 Ski Nautique / 2007 SV211 TE (gone but not forgotten)
  • charlesml3
    • Jan 2008
    • 2455
    • Lake Gaston, NC
    • 2022 G23
    Raw Water Impeller: every spring regardless of hours.
    • Jonny Quest
      • Aug 2014
      • 384
      +1
      I'm a little OCD...but I also change my tranny fluid every spring with the oil.
      JQ
      • hal2814
        • Jun 2016
        • 541
        • Ft Worth, TX
        Replacement isn’t the only form of maintenance. Inspection is important, too. I inspect the shaft log and rudder log at least yearly even though I have a drip less log these days. I also inspect the drive belt and check engine alignment. As far as drive belt specifically, I carry a spare onboard. There’s nothing as frustrating as losing a day on the water because you didn’t bring a big rubber band and a wrench. I strictly replace steering cables these days and only do that at first sign of stiffness. I don’t think the modern ones even have zerk fittings. Greasing them never worked out for me.
        If you trailer, inspect your bearings, grease if appropriate, check your tires, check tour lights, and check your braking system.
