best way to drain the fuel tank in a 1990 SN
  • uncle-buck
    • Jun 2004
    • 29
    • Houston, TX
    Haven't used the boat in four years and want to drain the fuel tank.
    A siphon hose with brass end would not go into the tank when feeding from the fill hose fitting.
    What's the best way to drain the tank?
    Did a search and did not find a good answer.
    \"Helping you make smart choices about your money - so you can live a better life.\"
  • uncle-buck
    • Jun 2004
    • 29
    • Houston, TX
    OK, I learned that it's easier to put a siphon hose into the top of the fuel tank by removing the fuel level sending unit.
