Newly purchased sport 200
  • Macca2601
    • Aug 2020
    • 4
    • Australia
    • 2016 Sports Nautique 200
    Hi all. I just purchased a sports 200 2016 and cannot manage to remove the prop nut.The prop is damaged and needs work. I am concerned about putting a lot of pressure on it with a ring spanner. I have hit it with some 5-56 and will let sit overnight but I does seem very tight. Any help would be great. Cheers
  • Spud
    • Jul 2006
    • 218
    • Echuca Australia
    • 2007 206 limited 2008 206 limited 2007 196 se 2010 200 team
    Seized? Corroded?
    • Macca2601
      • Aug 2020
      • 4
      • Australia
      Not corroded. Everything looks clean. I not sure about seized. My biggest worry it putting to much pressure on it and bending something.
      • Spud
        • Jul 2006
        • 218
        • Echuca Australia
        Worth Rost-0ff blue ice
        • Macca2601
          • Aug 2020
          • 4
          • Australia
          Thanks mate. I’ll give it a shot.
          • bturner
            • Jun 2019
            • 1576
            • MI
            • 2016 200 Sport Nautique
            Once you've gone through all the chemical solutions (penetrating oils and such) I would hit it with either an air or electric impact gun. An impact gun will localize the torsional load directly to the nut. Using a socket will also keep you from slipping off the nut and rounding off the nut or worse yet hurting yourself. Also block the prop with a section of 4x4 against the hull to spread the load of the blade against the hull.
            • Macca2601
              • Aug 2020
              • 4
              • Australia
              Thanks so glad I found this forum. Great to tap into the experience of you guys. I’m an impact gun kind of guy but not on something I know little about. It make sense to just hit it and rattle it off just don’t know the impact upstream so very wary on loading anything up.
