We just picked up a new to us 2003 SANTE, and the swim platform is causing the transom to flex at the mount. I noticed that the platform angles down, and I'm wondering if it's just due to the brackets going bad, or do we need to install some backing plates inside the boat? Has anyone else had this issue?
Tags: None
Sure thing. Below is a picture of the angle of the platform, and a video of the transom flexing at the mount.
Video: https://photos.app.goo.gl/V2m3NtamZ9idMPKk6
Can we assume you checked all the bolts on the back side of the mounts, and they are all tight?
I will have to look at mine this weekend to see what mine looks like.
Honestly, it feels pretty sketchy even in the water. I really don't like to stand on the edge of it as I can feel it flex under my weight (185lbs). It makes me really nervous when my kids jump on it and I'm out there. Just feels like something could snap (probably in my head, but I can't recall any other swim platform I've been on feeling that way).
I have an 03, and I dont have any flex. I watched your video and I cant see flexing. I will say, if the brackets are loose where they screw into the platform (via wood screws) it will flex.
Sent from my SM-J337V using Tapatalk
So I went through last night and re-tightened all of the bolts. It made a little difference, but it still bends/creaks. It did make me realize that the platform is a bit loos on the brackets. I'm assuming it should be pretty solid/tight on there, and I shouldn't be able to jiggle it around the attachment points. Maybe I just need to get some new brackets.
