Hi Everyone,
Glad to be part of the Nautique community. My overall issue that I need help with troubleshooting is with my 98 Ski Nautique(with a GT-40 and EFI) which feels like it is stuck in "limp mode". The max forward speed I can achieve is 8 mph at 1500 rpm's. I purchased the boat in early July this Summer, was not able to test drive the boat, but did test the motor with a fake a lake before purchasing and my mechanic friend looked through the entire boat. Everything looked good and the motor sounded great. I can achieve full rpm's in neutral and in reverse gear, just not forward throttle when the boat is in the water. Also, the past owner has been very involved trying to help solve the issue, he said he had the boat out on the Delta 5 days before I bought it and everything worked perfectly.
After lots of research, talking with multiple mechanics on the phone and in person, below is what we have done to try and fix problem.
We have replaced the following sensors: Throttle position sensor, heat temp sensor, knock sensor, oil pressure switch, oil pressure sending unit, and checked the transmission fluid to make sure it was full.
A few mechanics mentioned it could be the ECM is bad or the forward gear in the transmission is bad. We have been testing the transmission and we have not felt it slip once.
The previous owner said he replaced the oil pump, starter, impeller, battery, and fuel filter before before I purchased the boat.
Our next step for troubleshooting is to take the boat to the lake with the previous owner and a Rotunda Star Tester to see if the ECM is faulty. Back up plan to this is we have an appointment with Inland Marine Marine Sales & Services on Sept 7th to look at the boat.
Please let me know if you have any recommendations to help troubleshoot and fix my boat?
Much appreciated
Much appreciated
