Hey. So it's confirmed that my ECM in my 95 Ski Nautique is toast. Engine has 1300 hrs on it but has been running great. Compression test shows a little bit of differentiation but acceptable. Everything else checks out fine but I guess with that many hours on it you could say it's a tired engine (?)... Just seeing if anyone has put in a used ECM from nautique parts or gt40ecm.com? Other options? Whats a full engine replacement cost? Would be nice but maybe a pipe dream. Thanks for your input!
There are a few on eBay too
https://www.ebay.com/itm/Ski-Nautiqu...QAAOSwmINbaQ1b
https://www.ebay.com/itm/Ski-Nautiqu...YAAOSwYUlbYu8o
Here is one I offer up.
Check out this 1995-2002 ski nautique gt40 ECU for $499 on OfferUp.
https://offerup.co/h6NhharlT8
Originally posted by Adam B View PostHey. So it's confirmed that my ECM in my 95 Ski Nautique is toast. Engine has 1300 hrs on it but has been running great. Compression test shows a little bit of differentiation but acceptable. Everything else checks out fine but I guess with that many hours on it you could say it's a tired engine (?)... Just seeing if anyone has put in a used ECM from nautique parts or gt40ecm.com? Other options? Whats a full engine replacement cost? Would be nice but maybe a pipe dream. Thanks for your input!
Sent from my SAMSUNG-SM-G870A using Tapatalk
No it was on here where the fix was worked out. For around 200 you can have a working ECM. Or have Peter look yours overI was going to wait till spring to announce this, but I have some possible good news for those of you worried about lack of replacement ECUs. I was working
Originally posted by Peter6000 View PostWhat is wrong with yours? I can may fix it if you send it to me.
I'll get some details for you from the mechanic - he had an old tester (looked like a pin board of some sort) they used for these ECM. He said something about permanently grounded and it was causing the fuel jets to run wide open. Even with the fuel pump not on it was sucking fuel right from the tank. He'd never seen anything like it. Also the emc wouldn't go into test mode.
There are 2 transistors that drive the injectors. The can be replaced.
