So what was the consensus??
  • Flux
    • 408
    • Palmdale, Ca.
  • surroundsound64
    • Jul 2005
    • 2147
    • Longview, TX
    • 2018 230 1981 Ski Nautique
    RE: So what was the consensus??
    Well... I'd say #2, because you can't fix much with a red x. Yellow_Flash_Colorz:
    2018 SAN 230
    1981 Ski Nautique
    Sold - 2011 Sport 200V
    Sold - 2000 SAN
    • bobchris
      Banned
      • Apr 2006
      • 359
      Re: So what was the consensus??
      Originally posted by Flux
      prepared to fix any minor problem provide you can use the stuff in the lower box that is or are willing to let someone else use them for you :o :o
      • ag4ever
        • 1180
        RE: Re: So what was the consensus??
        10' pole,
        Poke
        Poke
        Poke
        • bhall
          • Aug 2006
          • 5
          If you are changing your impeller. It is not a difficult job depending on your mechanical skills. I have done it once, though not on a Nautique, but the same type of pump. I took nail polish and drew a line from top to bottom on the pump to make sure I got it back together right. If I remember right, it should only spin counter-clockwise if you have it back together right. (Maybe someone else can correct me if I am wrong). Write notes if your memory is like mine.
          If you can't get it back together, take it somewhere to get it fixed. You would have had to do so anyway.
          • EchoLodge
            • Jan 2004
            • 616
            • Huntington Beach, CA
            • 99 Super Sport
            Easy as pie!
            5 minute job but do as mentioned and make a mark so you do not install the pump up side down!
            sigpic
