Does my Nautique have Surf Select
  • LakeGuy91
    • Aug 2020
    • 8
    • Ontario
    • 2019 SAN 210 2003 SAN 210 1978 Ski Nautique
    Hi, I am just wondering how I would check to see if my 2019 SAN 210 came equipped with the Surf Select option (based on the build sheet i received it does not look like it).
    If my boat does not have it, how much does it cost to set it up? Surf select and watch? and does it require the dealer.
    Thanks,
    Jeff
  • charlesml3
    • Jan 2008
    • 2454
    • Lake Gaston, NC
    • 2022 G23
    The System display will show you all of the various firmware versions installed. If you have Surf Select, it will be listed there with it's firmware.
    -Charles
    • GMLIII
      • May 2013
      • 2797
      Garmin watch will run you between $550-$650 depending on model. 3.0 Surf Select module will run around $250.00 plus labor. Maybe you could have it all set up hopefully for around 1 grand plus/minus
      • LakeGuy91
        • Aug 2020
        • 8
        • Ontario
        Thanks for the info. Seems crazy they would sell a new Nautique without this option haha! I usually have a variety of 1-10 people in the boat and the only luxury that I don't have is the luxury to manipulate the wave on the fly.
        • greggmck
          • Oct 2014
          • 795
          • Bellevue WA
          • 2023 Paragon G23
          You have that already. Just yell it to your boat driver!
          Sent from my SM-G965U using Tapatalk
