Audio alarm for low fuel 2007 Ski Nautique 196
  • DennyG95
    • Jun 2007
    • 11
    I trust someone has been down this road before. My 2007 Ski Nautique low fuel alarm starts beeping when there is about a 1/2 tank of fuel left, which is incredibly annoying. Is there anyway to adjust the setting (so it goes off at a lower level), or minimize / muffle the alarm ? I don't think disconnecting it altogether is the right move, as the alarm MAY be essential IF another problem were to arise.
    Surely other Nautique owners have experienced similar. Looking forward to hearing solution ideas !
  • DennyG95
    • Jun 2007
    • 11
    Correction 2007 SN 196....my bad
    • Fast351
      • Oct 2006
      • 315
      • Winsted, MN
      • 2001 Ski Nautique
      Only way to fix it is to replace the Faria gateway box. Maybe Faria can reprogram it for you (they removed this in firmware, I found the rev notes at some point).
      I had the dealer replace my gateway box in 2008 on my 07, to fix it. As you probably know, those boxes are now unavailable, so reprogramming your existing one is probably the only solution. I would call Faria and ask. They've been really good to deal with on other issues for me in the past.
      2001 Ski Nautique / 2007 SV211 TE (gone but not forgotten)
      • DennyG95
        • Jun 2007
        • 11
        Can the sending unit and float be adjusted at all ?
        • Fast351
          • Oct 2006
          • 315
          • Winsted, MN
          • 2001 Ski Nautique
          Maybe. I think they use a 240-33 ohm sender on those. You could replace the gas gauge, wire the sender directly to it, and put a dummy plug into the Faria gateway to make it think the tank is always full.
