Help Needed: Heated Seat Switch Not Working
  • MNSuperAir
    • Sep 2005
    • 591
    • St Paul
    • 2016 SAN 210
    Hoping someone can help me on the forum. I have a 2016 210 with heated seats. The drivers side switch does not light up or work to turn on the seats. I am able to turn on the driers heated seat from the Link though so I know the seat works. Passenger side works fine. I did replace the switch (button) with a new passenger side switch I order from White Lake but still having the same issue.
    Few questions:
    1. Are the switches different passenger to driver? Only reason I ordered the passenger and not the drivers is the lettering on the passenger was rubbed off so I pulled the plate off to switch out with the passenger side.
    2. I checked voltage in the wires coming to the switch and did not see any voltage. It appears to be a signal wire only so maybe no voltage needed. Does anyone know if I should be able to measure voltage between the pins?
    I have not seen a harness drawing for the 2016 210, only the 2014 210 or a 2015 G23. Neither one is the same wiring as the 2016.
    Thanks for the help in advance.
    2016 SAN 210
    2006 SANTE sold
    2001 SAN - sold
    1991 Sport Nautique - sold
  • MNSuperAir
    • Sep 2005
    • 591
    • St Paul
    • 2016 SAN 210
    Well, I feel like an idiot. I was able to track down a 2016 210 wiring diagram and noticed no drivers switch in the harness. The switch on the drivers side is for the shift override. Guess everything is working as expected then.
    210 harness drawing can be found here.
    2016 SAN 210
    2006 SANTE sold
    2001 SAN - sold
    • charlesml3
      • Jan 2008
      • 2454
      • Lake Gaston, NC
      • 2022 G23
      Correct. There is no manual switch for the driver's side. It's controlled through the LINC only.
