Hi a couple months ago I bought a 2001 super air nautique. The boat never ran right and I’m getting water in the oil. Milky dipstick. Pretty sure I was ripped off. What are my options for new engines? Does anyone have recommendations on a new engine? I was looking on eBay and seeing some in the 2 grand range but wasn’t sure exactly what I needed. Do you guys know the part number or which engine to look for? Thanks, appreciate the help.
Tags: None
OK, before you start going out and buying a new engine, figure out exactly what's wrong with the one you have. It might just be a cracked head which is perfectly repairable. You need to get a good mechanic to go through and figure out how you're getting water in the oil. There are many possibilities that don't require replacing the entire engine.
-Charles
Charles is taking the correct and sane approach.
If that doesn't work out and you need another motor most people look at Jasper and Michigan Motorz for a replacement. The next question ends up being about new versus re manufactured. Jasper is considered by most to be the king for re-manufactured engines. They come with an industry leading warranty and most times can recommend a shop to do the swap for you. Around where I live (MI) Michigan Motorz is king and while they do sell some re-conditioned engines they're mostly known for their new engines. They're known for their quality and service but won't do a swap for you even if you're local. They do have several shops they can recommend though.
https://www.jasperengines.com/
https://www.michiganmotorz.com/
