Gauge of the stainless steel locking wire to secure the packing nut and locking nut
  • Elliott
    • Aug 2015
    • 8
    • Anderson, S.C.
    • 1997 Ski Nautique with 351w PCM/carburetor-equipped engine purchased on May 29, 2019
    What gauge stainless steel locking wire is used by Correct Craft to secure the packing nut and locking nut on a 1997 Ski Nautique? Thanks very much for any input.
  • gun-driver
    • Apr 2011
    • 132
    • Pittsburgh Pa
    • 1985 Ski Nautique 2000 Sport Nautique
    I use whatever my mechanic has in the hanger at the time, 025 or 041 is what I've used in the past
    • charlesml3
      • Jan 2008
      • 2460
      • Lake Gaston, NC
      • 2022 G23
      Don't overthink this. It's just safety wire to make sure the bolt doesn't back out due to vibration or something. If I don't have stainless steel wire around, I just use solid-core copper. I have a reel of irrigation control wire and just pull one strand out, strip the insulation off and use that. Copper won't rust and it'll certainly keep that bolt from backing out.
      -Charles
      • Elliott
        • Aug 2015
        • 8
        • Anderson, S.C.
        Charles, Thank you very much for your helpful advice.
        Elliott
