Does anyone have an inexpensive way to get the hours off the ECU? Since Nautique has no solution and the factory customer service does not want to help, there has to be an outside way to retrieve the hours. (2008 SAN 230 with the factory hour meter that stops at 999.9). My local dealer will usually give me a quick read but it is a PITA to pull the boat and trailer it down there just to read the hours. Seems like Nautique could do something to make this process a bit easier. And no adding a separate hour meter that starts at zero is not something I want to do, nor should anyone have to. TIA
- Mar 2002
- 16462
- Lake Norman
- Mooresville, NC
About all you can do is order Diacom software and the appropriate connectors.
https://www.rinda.com/acro/prodlist.pdf
https://www.rinda.com/acro/DiacomMarine.pdf
Originally posted by NautiqueJeff View PostAbout all you can do is order Diacom software and the appropriate connectors.
Originally posted by Neptune442 View PostSo what's the harm or trouble in adding a cheap and easy hour meter in the engine compartment?
