Emwt2
  • Hyong1005
    • Mar 2017
    • 25
    • Virginia
    • 2015 SAN 230
    Emwt2
    Hi all. Ive looked for this error code in the forum but I have a unique situation. This warning comes on only when I am wakesurfing with some ballast and going at less than 11mph. This code does not appear anytime other than that, normal cruise speeds or even when Im going slower than 11mph without ballast. It also comes on at random temps btwn 165-170. Its happening more frequently this year whereas I had it happen a couple of times last year.
    Is this a sensor problem like others have had and need a reprogram?
    Does my freshwater pump need to be replaced? Impeller? Thermostat?
    Thanks inadvance for your help!!
  • Infinity
    • Sep 2017
    • 730
    • Lake Norman - Denver, NC
    • 2014 SV244 w/ ZR409
    EMWT = Exhaust Manifold Water Temperature.... So EMWT 2 would likely mean that you have a faulty sensor on the 2nd sensor
