Symptoms of a failing ProTec coil pack / EMS?
  • dba4life
    • Sep 2004
    • 223
    • Raleigh, NC
    Hi
    94 Sport Nautique with the proboss 5.8 HO with the Protec EFI.
    For those who have had issues with the coil packs or engine management system what were the symptoms that caused you to replace it?
    Kevin
  • etwman
    • Jun 2005
    • 114
    • Denver, PA
    • 2007 Super Air Nautique 220 Team Edition
    Mine were intemittant backfiring and hesitations around mid to upper range. Never had issues out of the hole. In addition, it never acted up really when it was cold, after about 10 minutes it started having fits. Went back to the Mallory distributor and wires and its been fine ever since.
    Mine was a '94, so it wouldn't surprise me if that's your issue.
    Current Boat: 2007 Super Air Nautique 220 Team Edition
    Former Boat: 2003 Air Nautique 216 Team Edition
    Former Boat: 1994 Ski Nautique
    • Quinner
      • 2246
      • Correct Crafts
      On my 93 the symptoms were pretty much the same as etwman, the warmer the motor got the worse it got, it even started having a difficult time restarting while hot. After the conversion kit from DIM I think it ran better than ever.
      • dba4life
        • Sep 2004
        • 223
        • Raleigh, NC
        OK - Interesting. Both of you went to carburated systems and stopped using EFI?
        I am having an intermittent engine miss. Happens while under load. It happened about 3 weeks ago. Boat has run fine since. Been about about 4 times. Then it came back last Tuesday. When it starts missing it is unusable. Then boat actually went back and worked fine after idling for about 15 minutes. Last 2 times out this past Fri and Sat the boat ran great. No issues.
        Today it is in for some testing, new plugs, fuel filter.
        • etwman
          • Jun 2005
          • 114
          • Denver, PA
          Yeah I would trouble shoot the small stuff first. Do the filters, plugs, etc. It's a cheap elimination. If it still throws a temper tantrum then look into the CDI box. The problem with those CDI boxes is they act up when the want to which will drive you absolutlely nuts. You can't predict it and you can't make it act up.
          My boat is carburated, If I remember correctly in 94 you had either option. It was their first year they had EFI out or you could go carb. But the CDI box was the same on each. That's where the problem was, no doubt.
          Good luck.
          • dba4life
            • Sep 2004
            • 223
            • Raleigh, NC
            Thanks for the reply. I have the EFI and the only way I can keep it is to get the coil pack from PCM. (If it turns out to be the pack).
            • Quinner
              • 2246
              • Correct Crafts
              My 93 was the carburated Pro-Boss, the kit replaced the protec computer, trigger wheel, wires, etc.
