Where to find ballast switches for a DIY ballast system install. I remember reading on here some months back someone suggesting something other then OEM but can't find the thread. Any help would be appreciated, Thks
RE: Where to find Ballast Switches / Doing a DIY install
Got some from redden marine, they have a good online site and stock several manufacturers. Google search marine rocker switches. You probably only need to use SPDT, Single Pole Double Throw. I also put some little 6 amp pushbutton breakers before the switches to guard against shorts.
I used the cole hersee illuminated rockers with the dots on them. They are OK and actuate well, the lights are goofy and not really all that visible for the most part. I used mine for aerators.
http://www.reddenmarine.com/site/new...d=CHR5832706BP
Note that when you are ordering or looking you want on-off-on, not (on) off (on). If it's in paranthesis then it's a momentary switch.
I got mine from here.
https://www.surplusunlimited.com/Mer...ode=0400-90-50
Chris
waytekwire.com is a good source for carling switches as well, much cheaper than my marina. If you want switch actuators that are screen printed "fill" "drain" then you will have to order those from a dealer.1995 Super Sport, GT40 with EFI
NDT Tower, plumbed ballast, PP
