On the older Gs you had to ream the prop if it was brand new. Does anybody know what year you could stop doing that since they have updated the shaft a few times since then?
- Aug 2014
- 380
- Salt Lake City, Utah via Texas
- 2003 Ski Nautique 206 Limited with ZR6 Engine
Reaming? I assume you are referring to lapping the prop to the taper of the shaft. That really is the correct way to mount a new prop onto a tapered shaft. The woodruff key is not what keeps the prop and shaft properly joined, but rather the tapered fit of prop/shaft.
JQ
