Hi,
I've had an intermittent issue that seems to be more persistent now. My Perfect Pass Wakeboard Pro will sometimes stop reading the speed. I figured that something was stuck in the paddle wheel, but it's spinning freely. The boat is an '07 SV211, and when the PP speed is not reading, the boat speedo won't read either (the boat speedo also runs off the paddle wheel). I've pulled the paddle wheel assembly, and with the boat powered on (but not running), I would think the PP would read a speed if I manually spin the wheel, but it doesn't.
I've seen that the wheel can be replaced. Could that be the culprit, even though mine spins easily? Any thoughts or other diagnostic ideas for me?
Thanks!
Thanks!
