Tracking Fin Replacement
  • Funwine
    • Aug 2020
    • 2
    • Sacramento, CA
    Could anyone tell me if removing and replacing one of the three tracking fins on the bottom of the boat (97 Nautique) is a difficult process? Would it require special tools, calking or sealant
  • CW320
    • Sep 2020
    • 1
    • Sacramento and Lake of the Ozarks
    • 1998 AIR Nautique
ID:	623947 Pretty easy. Remove, clean up surface, and reinstall.
    • Funwine
      • Aug 2020
      • 2
      • Sacramento, CA
      Thank you for your feedback. I truly appreciate it. So removing the screws was easy? It didn’t require a impact driver to remove them?
      • srock
        • Oct 2008
        • 1066
        I have a broken one to replace as well. I was thinking 4200 over 5200 in case it happens again.
        • havoc
          • Jul 2020
          • 14
          • Chicago
          Some screws come out easier than others, just hand tools, heat from heat gun helps, also plastic razor blade scrapers help in removing all the old sealant. I purchased new stainless steel screw to save time in trying to clean the old ones. Also used acetone to clean up old residue and any slop after installing new, use gloves and respirator
