PCM V-drive drain/fill plug removal
  • mf01
    • Jun 2005
    • 515
    • Austin, TX
    The manual mentions checking for contaminates and fluid levels every year on the PCM V-drive. I'm trying to remove one of the drain/fill plugs. Is there a trick to removing it? It's square, so I'm using a normal wrench. It appears that 10mm is the right size (I thought it would be SAE). I'd rather get a larger ratchet on it, but don't have any square sockets. I'll probably spray with liquid wrench penetrating oil to see if that helps.
    Previous:
    2011 Super Air Nautique 210
    1994 Sport Nautique
  • hal2814
    • Jun 2016
    • 541
    • Ft Worth, TX
    I think the problem is that it’s painted with the plug already on. I had some luck with running a razor around the plug before removing it to cut the paint. That made it a lot easier.
    • mf01
      • Jun 2005
      • 515
      • Austin, TX
      Did you use a standard wrench?
      Previous:
      1994 Sport Nautique
      • hal2814
        • Jun 2016
        • 541
        • Ft Worth, TX
        I used a big adjustable wrench. That way I could get the size down small enough and still get some torque on it.
        • Infinity
          • Sep 2017
          • 730
          • Lake Norman - Denver, NC
          • 2014 SV244 w/ ZR409
          I used a box wrench to remove mine, I think a 3/8" fit it real snugly? Socket set seemed to want to strip it and there is not much room down there. The first time removed is a bear cause the threads are coated with some kind of paste. I stopped too after trying the first time cause I thought something was up.
          • mf01
            • Jun 2005
            • 515
            • Austin, TX
            I haven't attempted to loosen this again. I was thinking about using crows feet to get more leverage with a 3/8" torque wrench.
            Previous:
            1994 Sport Nautique
            • Nick Heimer
              • Apr 2015
              • 69
              • Omaha, NE
              • 2005 SANTE 210
              I use a small adjustable/crescent wrench, but it is very tight.
              I have notice that I never get any water out of the Walter V-drive on my 2005. Have others seen the same?
