I just purchased a 2006 SANTE 210 and doing some maintenance items before it goes on the water. I have replaced the low-pressure fuel pump and the high-pressure pump in the FCC. While doing this work, I decided to replace the fuel lines. The low-pressure fuel line had red tape around it at the tank and the pump. I am guessing this was done at the factory to identify which line goes to each connection. When I pulled the floor up to connect the lines at the tank, one of the tank connections is painted red on top. See the picture below.
It looks like the fuel tank has been removed in the past - when they replaced the steering cable, and I wonder if they reconnected the lines correctly. It would seem that the fuel line with the red tape on it would go to the red mark fitting, but it is not connected that way. Does anyone know is there a difference between the two fuel tank connections?
Does it matter which connection goes to the FCC and which one goes to the low-pressure fuel pump?
