I bought the boat with "imperfections" and spent the better part of yesterday wetsanding and buffing oxidation. I got 90% of it out but this spot appears to have been repaired before? The darker ring is almost like orange peel. I think if I could at least get it smooth and polished the rest would somewhat blend. Is there hope or am I looking at a gelcoat job? You can also see somewhat of a lighter colored line just below the rub rail. Above the rub rail is flawless as it sat the majority of its lift with a cover.
My process was 1500,2000,3000 then 3m gelcoat compound followed by chemical guys swirl/scratch remover finished off with chemical guys polish. As you can see in the 2nd pic it was looking good minus that spot.
