I have a 2017 G23 Coastal Edition with the H6 and oem heater. Curious what you guys are doing to winterize? I've read through the forums as well as the owners manual, it appears to be directed towards the no coastal editions. I haven't determined if I will be able to move the boat inside the basement yet so getting prepared if im not able.
- Mar 2002
- 16519
- Lake Norman
- Mooresville, NC
Just pull the blue plugs and empty the water strainer bowl. That's all you really have to do. The heater on a FWC engine will have anti-freeze running through it, so leave that alone.
Here are the drains on a fresh water cooled (closed cooled) system.
- Mar 2002
- 16519
- Lake Norman
- Mooresville, NC
Actually, it may not. There wouldn't be a place for the plug in the plug holder, so I wonder if that's a misprint in the manual. The plug holder for the raw water cooled engine has a place for that plug, but the fresh water cooled plug holder does not. I bet that engine doesn't have that drain.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
I have the 2017 coastal edition 230 with the H5 motor. I have not been able to find this #1 plug. I have been around the backside of the engine replacing a leaking hose and have not seen it. If you find it let me know. I do the antifreeze flush since I am not sure it this something that I just am missing and it needs to be drained??
Originally posted by Paul W View PostI have the 2017 coastal edition 230 with the H5 motor. I have not been able to find this #1 plug. I have been around the backside of the engine replacing a leaking hose and have not seen it. If you find it let me know. I do the antifreeze flush since I am not sure it this something that I just am missing and it needs to be drained??
