Steering Cable on 2000 SN
  • Cwurf
    • Sep 2020
    • 8
    • AB
    • 2010 Glastron
    I realize there is a post with photos however my gas tank is flat on the floor not tucked up in the backend like the 1998, My tech is telling me he had to remove the gas tank in order to replace the steering cable.
    He is really good, but He did say he has not done this on a 2000 before, does that tank actually have to be removed?
    Thank you
    Carl
  • steepndeep
    • Oct 2014
    • 22
    • Hawaii
    • 2000 Pro Air Nautique
    Hey Cwurf, I just removed mine because it was corroded and junk. I had the fuel tank out because I needed to drain and clean it (boat sat for five years) which did make getting to the rear mount much easier. I will definitely try to install a new cable without removing the tank again. Its somewhat of a pain in the ***. Question for you: Where did you source your new steering cable? I need a new one as well. Thanks and good luck!
    Kasey
    • Michael Crouse
      • Jun 2017
      • 79
      • Iowa
      • 2000 Ski Nautique
      I have done it on my 2000 ski. I didn't remove it but I had to detach the hold downs and the fill and vent tubes so I could slide it forward to access the rudder and cable end. It's a pain because I have to do it every year to grease my rudder. Sometimes twice ( like this year) because I put over 100 hrs in it.
      i sourced my cable from Nautique parts.
      Mike
      • Cwurf
        • Sep 2020
        • 8
        • AB
        • 2010 Glastron
        Kasey
        Hi Kasey, I am in Edmonton and just got it through the local dealer 350 CDN dollars or so, its 19.5 ft don't get a 19 too short.
        How is the skiing in Hawaii? is it hard to find some flat water?
        Carl
        • Cwurf
          • Sep 2020
          • 8
          • AB
          • 2010 Glastron
          Mike
          Wait what? every year you grease the rudder is that a bit much?
          Carl
          • Michael Crouse
            • Jun 2017
            • 79
            • Iowa
            • 2000 Ski Nautique
            I think it makes the handling so smooth. New cable is 90% but grease on the rudder makes it drive perfect.
            • steepndeep
              • Oct 2014
              • 22
              • Hawaii
              Carl
              Hey Cwurf, yes we are very limited to flat water out here for every day use. There is the Keehi Lagoon which was dredged a long time ago for sea plane landings, and also the Kaneohe Bay sand bar.
