Which is best to use in your block? RV or th eother stuff. What does everyone else use?
Tags: None
RE: RV Antifreeze or Straight antifreeze
Either will work fine. If you use the regular green antifreeze, youll want to dilute it 50/50. I like the RV stuff becuase its premixed and biodegradable. In the spring, I just reattach the water pump, put it on the hose and blow the antifreeze right out.1990 Ski Nautique
NWCT
The regular stuff should be collected prior to putting your boat in the water. This means you need to drain the block, the put a bucket under the exhaust and run it on a fake-a-lake to collect the remaining antifreeze. Then it must be disposed of properly.
The RV stuff can be flushed right into the lake the first time you run the boat, that is why I vote for the RV stuff.
Re: RE: RV Antifreeze or Straight antifreeze
Originally posted by 1998CanadaNautiqueHow many Litres does it take?
RE: Re: RE: RV Antifreeze or Straight antifreeze
You really should drain the block first. Diluting the RV antifreeze makes it virtually worthless. It will take about five gallons if the block is drained.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
We will get a few nights in the -20's & -30's every winter. I do not drain my block but run gallons undiluted via the strainer hose. Now with the SAN, I use a fat sac pump in the bucket under the exhaust, pump to another bucket, and recycle it for about 20 minutes, run the heater, shower, etc.
I have just done the fill and shut it off method for years on my other boats also without recycling and have never ever had a problem.
I do agree that you ought to drain it, but......... if you were going to have a problem, good old MInnesota winter are the place for it, and I do not worry.
M
<sigh> noting that I will have to apply this procedure soon is not that exciting.the WakeSlayer
1968 Correct Craft Mustang
Remember that some RV anti-freeze is for plumbing an not for engines.2008 Super Air 210 Team
2004 AIR 206 Team
1997 Ski Nautique 196
1993 Ski Nautique SNOB
Use the RV, better for everyone.2016 SAN 210
2006 SANTE sold
2001 SAN - sold
1991 Sport Nautique - sold
2004 AIR 206 Team
I think there is a misuderstanding about RV antifreeze and engine anti-freeze. When people say to use RV antifreeze it is the plumbing antifreeze not RV/regular gas engine antifreeze. I would use the plumbing antifreeze over and engine antifreeze (green) just for the simple fact that if you drop any in the lake you are poisoning everyone. The best way is to drain the block and all lines and then run RV plumbing (100%) through everything. The block does not need to be filled to the brim rather a gallon just to prevent the trapped water in the water jackets from freezing. I hope this clears it up.
They make engine anti-freeze that is biodegradable. It is usually blue..............if you look at a lot of the pink stuff, it will say that it is not for engines. It does not have the anti-corosives that the engine needs. Some of the pink will not protect the seals and will corrode the metal.2008 Super Air 210 Team
2004 AIR 206 Team
