I have a 2016 SN 200. The shock for the passenger loveseat was weak, so I got a replacement 80 lb shock from NP. The seat still won't stay up. Has anyone else had this issue, and were you able to find a stronger shock that fit somewhere else?
Is there one or two lift shocks on this seat?
Sent from my Pixel 3a using Tapatalk
Bellevue WA
I was wondering that same thing. Seems like it should have two.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
Not that have any experience with this boat...but on my 206, the lift shock for the front seat (full width tournament seat with a flip down for the bow access) is a 150lb shock. Doesn't your boat have a similar seat? I looked on NP and they don't specifically call out a shock for that boat/seat but if you look at other "observer seat" shock, there's a few there and they are larger than 80lbs. I believe my 97' closed bow ski used two 80lb shocks for the observer seat. Makes me wonder if 80lbs is right shock....for a single shock setup on a larger seat...seems kinda small.2004 206 Air Nautique Limited - Black with Vapor Blue (family style)
Bellevue WA
My 200 OB has two shocks on the passenger seat. However, I know the seat will stay up with one shock because one shock was missing when I bought the boat. The dealer sent me a second shock a few weeks after delivery. The part number is ML36-60. I think that means 60 lbs. So 120 lbs total.
