I have a 2003 216, What filter does it take? Cheers
RE: AC Delco Oil Filter for 216
What motor do you have?
Regardless, I believe that PCM uses the same remote oil filters on all of their motors, if that's the case, then you would need a Motorcraft FL-1, PCM uses a ford remote oil filter.How about \"Chales\"?
RIP Nikolai (\'05 SANTE) 5/23/05 - 4/30/06
That's a Motorcraft FL-1A.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
If you want to use an AC-Delco oil filter, it takes the PF-2. That is the one I use on my 2005 196 (w/ 330 Excalibur).
Re: RE: AC Delco Oil Filter for 216
Originally posted by DRAGON88Originally posted by NautiqueJeffThat's a Motorcraft FL-1A.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
