I feel a vibration in the steering wheel and hear a stange noise when I give the boat gas out of idle. It goes away after a second or two. Do you think something is out of alignment?
RE: slight vibration
Prop might be a bit out of shape also. I had this and it went away with a new prop. Vibration during the hole shot only.2016 SAN 210
2006 SANTE sold
2001 SAN - sold
1991 Sport Nautique - sold
RE: Re: RE: slight vibration
I did try tightening with no luck. But now I have a spare prop. It is worth checking the tightness.2016 SAN 210
2006 SANTE sold
2001 SAN - sold
Thanks. I will check it this weekend. Do I need a prop puller for this job?'18 SAN 210 Reef Blue/Admiral Blue Metal Flake
'12 SAN 210 TE Black/Masters Blue
'09 SAN 210 TE Black/Fury Red
'08 Air 216 TE
'02 Air 216
'98 Sport Nautique
'89 MC Prostar 190
I do the same as Larry, but as mine need to be "reworked" when i need to remove them, I don't really care if I ding the prop a bit more. just be careful you don't hit it wrong and bend the shaft or hit the boat bottom instead.
