So it looks like it's time to change the riser gasket on my ZR6. Buxton marine has them here local and I'm about to go pick them up but I can't seem to find any official torque specs online or in any of the manuals. Does anyone on here know them by chance?
A d m i n i s t r a t o r
- Mar 2002
- 16521
- Lake Norman
- Mooresville, NC
There is no torque spec published. I usually go with 25 ft lbs or so.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
- Aug 2014
- 381
- Salt Lake City, Utah via Texas
- 2003 Ski Nautique 206 Limited with ZR6 Engine
That can also be a gasket leaking, so you may want to R&R both risers and replace gaskets...mind the gasket orientation. If you reinstall with some anti-seize lube, back off the torque a bit so you don’t break the bolt.
JQ
The world is at your fingertips. Instead of taking someones guess why not just look it up?? PCM just does not make up the torque values- there are industrial standards. Here is a chart from Fastenal
‘Give a man a fish and he will eat for a day. Teach a man how to fish and you feed him for a lifetime.’
It can be more beneficial in the long run to teach a person how to do something than to do that something for them. Your welcome
Bellevue WA
Originally posted by SilentSeven View Post
"These estimated torque values are derived from the standard torque formula Torque = KDF utilizing a standard "free-spinning" nut (non-locknut) with a proof strength equal to or greater than the tensile strength of the bolt. For other applications or questions, email engineer@fastenal.com."
Use a locknut, a lock washer, thread locker, anti-seize, or any other normal combination and the calculator doesn't work.
