GT-40 throttle linkage question
  • FLCERIK
    • Jun 2005
    • 68
    • Reno, Nevada
    I was winterizing my GT-40 and noticed the 1/2" long brass nut with the small nut behind it was loose. Is this normal? What does this serve as? Should it be tight or set at a specific tightness. Will this effect performance? Below is a close up photo followed by an expanded photo. Any help would be great. Thanks in advance.
  • FLCERIK
    • Jun 2005
    • 68
    • Reno, Nevada
    RE: GT-40 throttle linkage question
    • Rick
      • Mar 2004
      • 1250
      • San Diego, Ca
      I'll check mine when I get home tonight. The chrome screw looks like a lock nut. Are they both loose or just the brass?.
      Nautiqueless in San Diego
      • FLCERIK
        • Jun 2005
        • 68
        • Reno, Nevada
        The long brass nut and the small screw behind it are both loose. It looks like the long brass nut should screw into the threads but it does not want to thread.
        • Daryl
          • 133
          • Brandon, Manitoba, Canada
          • 2004 Ski Nautique 206 1990 Ski Nautique
          the brass nut is the perfect pass cable connection. It threads onto the existing throttle cable but should not thread onto the other "tube" that contains the PP cable.
          I'm going from memory but I think it looks to me that your system has always been this way....
          I think you could snug up the back nut, just to make the brass nut doesn't move anywhere.
          Current Boat ==> 2004 Ski Nautique 206, LOVE IT!
          Former Boat ==> 1990 Ski Nautique, PCM351
            • 2908
            The small nut should be tight against the big nut (almost sounds obscene). The perfect pass installation instructions should include the details about this connection.
