Control panel
  • Jerry Gilliard
    • Aug 2020
    • 10
    • 2001 Ski Nautique, 2000 Century 3200, 1993 Hewes Redfisher18’
    Control panel
    Nothing works. Any help would be appreciated
  • Nautiquehunter
    • Jun 2008
    • 2080
    Does it have a separate toggle switch you have to throw first ?
    • Jerry Gilliard
      • Aug 2020
      • 10
      Not that I know of
      • tandcc
        • Jul 2018
        • 17
        • Hendersonville TN
        • Ski NAUTIQUE M235
        Is the button on your kill switch pushed in “all the way”? Sometimes the red plastic that holds it can relax.
        • bturner
          • Jun 2019
          • 1571
          • MI
          • 2016 200 Sport Nautique
          Is this the first time out for the season or have you disconnected and reconnected the battery before this happened? If so the first place to look is at the battery connection. After that look for the stupid stuff you'll kick yourself about later. My favorites are the shifter not being in neutral (make sure it's straight up and giggle it a bit to make sure the neutral safety switch is contacting), missing a wire when reconnecting the battery and as stated above the safety lanyard.
          If no joy with any of these check the 50 amp breaker on the motor. I've had these trip for no apparent reason before when reattaching the battery. And my last favorite is the power switch (if you have one). These are know to fall apart inside the switch. I had one feel funny when I turned it, then no power. When I pulled it off the power panel pieces fell out of it.
          • JAppler
            • Apr 2019
            • 167
            • FL
            Also check the bilge pump switch if installed...I use mine as a secondary battery switch and sometimes forget to flip it...
            • Jerry Gilliard
              • Aug 2020
              • 10
              I should have mentioned that the boat does run just nothing on the panel works
              • SilentSeven
                • Feb 2014
                • 1854
                • Bellevue WA
                • 2004 Nautique 206
                so...confused. How does "boat runs" align with "nothing on the panel works"? For example, how do you start the boat? Do the dash gauges work? Is it just the panel shown - accessory switches - that isn't working?
                I think a few more details would be helpful. Year and exact model of boat. Battery configuration. Any recent dash or other electrical work? Has it ever worked while you've owned the boat?
                Bellevue WA
                • James
                  • May 2007
                  • 151
                  • Indian Wells, CA
                  I am assuming you have a 2000-2001'ish model. Assuming your key pad, gauges etc. all work and only the "accessories" pad is not working I would first get behind the dash and unplug the pad. It is possible that the years of age have resulted in corrosion developing in the connector. Use a VOM to be sure you are getting power to the connector and have a good ground and good connection of the wires to the connectors. Be sure both sides of the connector are clean and making good contact. Plugging in and unplugging several time may help make better contact. Maybe you will get lucking and it will power up again. If not I is then like the pad is bad. I am not aware of any way to repair the pad unless of course you are some kind of electronic technician. NautiqueParts.com has replacements. Item#6293 for $395.
                  • James
                    • May 2007
                    • 151
                    • Indian Wells, CA
                    Just as a follow up to my last post and not trying to give you false hope that you won't have to spend $395 for a new pad but in my experience when the pad starts to go bad it usually presents as individual "buttons" start not working. Failure usually doesn't present as total failure of the entire pad all at once. Of course total failure could be a possibility. I think in your case total failure with no other prior issues leads me to believe/hope you only have a connection issue. Keep your fingers crossed and let this forum know of your findings so members can learn and continue to help.
                    • Jerry Gilliard
                      • Aug 2020
                      • 10
                      Hey everyone sorry for just now getting back to y’all and I appreciate all the info you are sending. The boat I have is a 2001 ski Nautique and it came with a house that we bought. The boat has been this way since we purchased it and I am just now trying to figure out how to get all this working. The boat runs all the gauges work the bilge pump comes on but the panel is dead which operates the blower NAV lights and fill tanks which I think it has and also the radio does not work. Previous owner bypass the kill switch which I am going to hook back up
                      • James
                        • May 2007
                        • 151
                        • Indian Wells, CA
                        On the 2001 SN there should be a 3 way ( ON/OFF/BILGE) toggle switch near the drivers feet. In the OFF position the dash/bilge pump/engine/stereo is all deactivated to prevent you from draining the battery. The BILGE position is used only when you plan to leave the boat in the water unattended and assure there is 12v available to the automatic bilge in the event your boat starts to take on water. It will allow the bilge pump to cycle as needed to remove the water up to the point the battery dies. In the BILGE position nothing else will operate. In the ON position you will have power to the dash to start the boat and use any other key pad/stereo etc. functions. If you are in fact putting the toggle switch in the BILGE position and the bilge pump is always on you either have continuous water in your bilge or the automatic float is malfunctioning and needs to be evaluated or the pump replaced. If you have the switch in the ON position and are able to start/run the boat and run the blower with the start pad to the left of the steering wheel AND can manually run the bilge pump using the pad to the right of the steering wheel but none of the other functions work you are most likely looking at a bad key pad and will need to replace it. As for the stereo, depending on the installation you might have to press the 12v button with the ‘lightning bolt”. It powers the accessories. As for the ballast tanks fill button your boat should not have come from the factory with tanks. Other models did have tanks and Correct Craft used the same key pad for the other models. As for the blower, it is operated by the start/stop pad to the left of the steering wheel. The fan button with the “squigglely” line next to it on the key pad to the right of the steering wheel is for the factory optional HEATER which you may or may not have. If you don’t have vents in the driver footwell you likely don’t have a heater. Go to the Manual/Brochure section at the top of the page on this site and scroll down to the 2001 SN owners manual. You will find a tremendous amount of useful information about your boat.
                        • Jerry Gilliard
                          • Aug 2020
                          • 10
                          Thank you for all the information. I will let everyone know what I find
                          • Jerry Gilliard
                            • Aug 2020
                            • 10
                            Pretty much narrowed it down to the switch panel can anyone tell me where is the best place to purchase one? Has power going in but nothing works and it does not light up. Thanks for all the info
                            • Jerry Gilliard
                              • Aug 2020
                              • 10
                              Pretty much Narrowed it down to the switch panel. Can anyone recommend the best place to purchase one and thank you for all the information y’all have sent. It has power going in but nothing lights up
