I can’t seem to figure out what this plug is for and what it plugs into I traced it back with the volt meter and found it’s grounded on the connections I marked with a sharpie on the ecm if anyone know please let me know it might be the source of my loping idle
- Aug 2014
- 378
- Salt Lake City, Utah via Texas
- 2003 Ski Nautique 206 Limited with ZR6 Engine
You may want to give this a try on www.CorrectCraftFan.com and see what those old-school guys say. You may want to provide a bit more info, such as engine model year and any issues / symptoms you may be having with the engine.
JQ
Look at this diagram.
https://planetnautique.com/CorrectCr...entHarness.pdf
the pins you have marked on the ecm harness look to be 20,40,& 60 which are ground, and 8 & 30. Pin 8 looks to go to the fuel pump pressure sensor?1998 SN GT40
84 2001 Ski Nautique (sold)
Monticello MN.
Just saw your screen name. Whats the story with a GT40 and a Shamrock? I'm in the process of putting a 40 in my Shamrock 20ft WalkThru as well.
You won't obviously have a green wire going up front to a light. The S.L.O.W. system senses if you have an overheat or low oil pressure and puts the engine into a safe mode which limits RPM and turns on the light on the dash.Last edited by gary s; 03-30-2021, 02:41 PM.
Also Gary the GT40 in my shamrock 200 Cuddy makes the thing fly is so over powered I’ve got it up to 45 on gps fully loaded and it was terrifying and if I didn’t have 2 people a live bait tank and a 300lbs cooler with wind it would have probably gotten up to 50+ I’ve got a speed prop for it but have no plans of putting it on
