2019 G21 leans to the right.
  • Twarren
    • May 2021
    • 2
    • Hawkins, TX
    • 2019 Nautique G21 2011 Nautique 210 (sold) 1997 Nautique (sold) 1986 Nautique (sold) 1980 Nautique (sold)
    Is this common? Will I have to use Ballast to correct this? Any suggestions?
  • GMLIII
    • May 2013
    • 2795
    Yes common problem . Throw 200 lbs of ballast bags under the observer seat and see if that corrects the problem . If not add another 50lbs .
    I have a G23 and I have 250 lbs of ballast under the observer seat at all times . No lean problem
    • BasaltRMK
      • Apr 2020
      • 281
      • Basalt, CO
      • 2024 SAN G23 2020 SAN G21 (Sold) 2018 SAN G21 (Sold) 2015 Tigé R20 (sold) 1972 MFG Gypsy-15 Tri-hull (sold)
      When does it lean? All the time, only at certain speeds, etc.? Neither my 2018 nor my 2020 G21 lean much. I do use lead to counteract the prop torque and the weight of the driver (and for the surf wave), but if I didn't surf I wouldn't have considered the lean as something noticeable enough that needed to be fixed. Is it possible that your ballast sensor(s) are bad and you have ballast in the starboard bag? Bad sensors are a known problem, and I think your 2019 likely came with the older style. Good luck.
      • Twarren
        • May 2021
        • 2
        • Hawkins, TX
        Boat leans all the time and is very noticeable. I will check out the ballast censors. I can add the extra ballast bags if it’s not ballast censors. Thank you for your help.
        • GMLIII
          • May 2013
          • 2795
          Very likely adding steel shot ballast bags will solve your lean problem. Easy fix
          • BasaltRMK
            • Apr 2020
            • 281
            • Basalt, CO
            Twarren - your description sounds to me like something is not right. I'm still thinking your boats holding water in the ballast. Either way I hope it's an easy fix!
            • Jonny Quest
              • Aug 2014
              • 380
              Leans to the right? With the current “Administration” leaning to the left, your boat may wind up in the middle.
              • scottb7
                • Aug 2011
                • 2198
                • Carson City, Nevada
                could you test this by seeing if any water comes out on trailer or in the lift?
                • Johnny_Rock
                  • Dec 2016
                  • 216
                  • MN
                  • 2021 G23 (Previously 2016 G23)
                  I think all the Gen II Gs have a slight lean to them. I know my 2016 G23 has one built in...
                  • Sammm724
                    • Jul 2020
                    • 60
                    • California
                    • 2011 SANTE 2001 Ski Centurion
                    Try tuning the rudder... see below form. I'm assuming this is the issue, very common.
                    https://www.planetnautique.com/vb5/f...oint-adjusting
                    • bird_dog0347
                      • Oct 2020
                      • 347
                      • DFW
                      • 2021 G23 Paragon
                      Is the boat listing to the right when you are just sitting on the water not moving or only when you're underway?
                      • GMLIII
                        • May 2013
                        • 2795
                        Could be the problem but I tried that on my 2017 G23 as it was leaning to the right and it did not help. Once I put the 250 lbs of steel shot ballast bags under the observer seat it quit leaning to the right.
