2010 Nautique 226 TE w/ZR409 - Fuel Pressure Sensor Location
  • Titan8750
    • Jan 2021
    • 22
    • TX
    Sorry the title is incorrect. I am unable to change it. It should read Oil Pressure Sensor.
    Just got the boat back from the dealership getting all fluids changed, spark plugs, and impeller done. I was not 5 minutes in the boat this past Sunday and the following warning code popped up every time I was over 4000 RPMS. Oil pressure gauge would read anywhere from 40PSI to 90PSI when I got on it the gauge would spike to 90PSI and the warning would pop up. Not sure if the guys working on the boat may have bumped the wire/connection to the sending unit or not. Anyways looking to fix or replace unit. However, I can not find any engine break down schematics online or on the PCM website to where this is located on the engine. Can any one point me in the right directions?
  • Titan8750
    • Jan 2021
    • 22
    • TX
    I was able to find some schematics of the zr409. Looks like the oil pressure sensor is on the starboard side of the motor toward the bottom.
    For those of you that have 226's how are you all pulling the side panels out? Since the engine hatch folds up and toward the back of the boat it does not go up far enough for to he side panels to be removed. Are you all just detaching the struts and manually lifting the engine hatch to a full 90 degrees?
    Part number 13
    Sent from my SM-G960U using Tapatalk
