Hey all - quick issue that I want to confirm. My 2020 G21 has the ZZ6 engine (love it). I have the factory heater option. As I understand this closed loop system, the engine cooling and heater core are all on the 'closed loop' portion of this system - i.e., only antifreeze / coolant, no raw water. So the only thing I need to drain when it freezes again (as it does at 8,400' in CO) is pull and drain the 3 quick-connect hoses. The heater core/system does not need to be drained separately. Am I understanding this correctly? I should know this, but the dealer winterized it last year when they did a bunch of warranty work. Thanks!
The three hoses with the quick connects plus the raw water pump and the raw water strainer bowl. I also pull the water line going to the drip less water shaft seal and blow it out with my mouth. This hose attaches to the main heat exchanger with a hose clamp.
- Mar 2002
- 16517
- Lake Norman
- Mooresville, NC
I would just pull the three quick-connect hoses, and also empty out the raw water strainer. Nothing else should be necessary.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
- Apr 2020
- 281
- Basalt, CO
- 2024 SAN G23 2020 SAN G21 (Sold) 2018 SAN G21 (Sold) 2015 Tigé R20 (sold) 1972 MFG Gypsy-15 Tri-hull (sold)
Jeff and mzimmer - thanks for the additional input. I pick up the boat Thursday, so of course today woke up to snow. Should be clearing. I'll likely go with Jeff's advice, since the temps are only forecast to drop into the low 30s, so looking like we won't have another hard freeze. Time to break out the wetsuit! Thanks all.
